97 LSC Mark Viii Air ride won’t pump rear
Jackherer420
Pleasant hill CA
So the air ride won’t pump rear, if I turn the car off 10 times and turn it back on it comes up sometimes but once I drive for. A minute it goes down and the air ride message pops up
I really need to get air in, none of the struts are bad front or rear
The front stays up no problem
I need to figure out what’s going on I’m not exactly sure what it is, ride height sensor? I need to get air in ASAP.
I need to
Buy the Ford tester is your best bet or fi d someone near you with one
You can pump the bags manually, if you need only to pump (and maybe a little ride).
Blue connection to open the desired bag to pump, red to pump or inflate (inflate schematics in the middle, pump - on the right).
Manual leveling will not be as perfect as automatic in any way.
I prefer thinking of "manual mode" as an emergency feature.
