96 Mark VIII trans
playboy4aday
white plains
What kinda problems if any will I run into by swaping in a newer 2000 mustang trans? Will I need to repin any connections? Thanks for any info.
I just got through doing the entire swap from a 94 trans to a 98 and all I done was changed over all the electrical internals, which was very simple to do. Once you have that done, your transmission will then be "plug & play".
Mine is working better than I ever imagined and I also had Max send me the two gaskets that I needed to do the J-Mod and that also was extremely simple to do. The link below appears to be a lot harder than what it really is. I swear, if I can do it, anyone on this site can do it, including the J-Mod. The trans swap is where the real work is involved.
http://sites.google.com/site/krackerskrazy8s/Home
