bigshow1122
Hello everyone,
I pre-apologize if this is in the wrong "area" of the forum. I am a new member to the forum from Indiana. I recently purchased a 93 lincoln mark VIII with 72,000 miles for a hair over $2,000 ( Will post pictures later) Anyhow, I bought it knowing it needed a new water pump. Anyhow, water pump change went smooth and I am attempting to get this crossover tube cap off. Let me tell you, I am a pretty big guy 6'3 260 and I am having the most hell of a time getting it off. I have tried Vice grips and the 1/4 socket like I have read on here which has been advised before. I have a good size pipe wrench I would love to put on there and try to get it off with but I am honestly afraid I might damage it putting that much torque on it. Should I be? Next to drilling and tapping like I have read also, is there any other way. I would be afraid drill shavings or something would fall into the cooling system and cause larger problems. Ok, now for the slaying I am going to get from you all. I filled from the reservoir and continued to while it was running to check the water pump for leaks. I have done this about 10 times and still managing to get air out of it but the temp guage peaks at about the very tip of the normal line almost going into red. I am wanting to get this cap off and do it right. Worst case scenerio what would happen if I start really going and applying elbow grease to the cap with the pipe wrench? Thanks for reading
