There is A LOT required to do the swap. You need to find a clutch pedal assembly, clutch master cylinder, drive shaft, relocate the PCM, clutch, PP, something to calibrate your speedometer, and a lot of fabrication to get the shift linkage to pop up in the floor.
It's doable, but you are doing it the hard way.
Check out this build thread at LOD. Jeremi went with a 3650, but there is lots of good info and pics regarding the clutch pedal and hydraulics as well, about half way into the thread.
http://www.lincolnsofdistinction.org/vbulletin/showthread.php?t=34233
You'll probably need to set up an account to see the pics though.
