NoLimit95
I need an answer from someone that knows. I can get a 4r70w that came out of a 2004 Mustang with a V-6. I have had the man match up the bolt patterns with a Mark 4r70w and everything is the same. Is there any reason the electrical internals couldn't be swapped out from a 95 4r70w into the 2004 4r70? Seems like it would be the same as what I done on the 94 when I swapped over to the 98 trans and swapped out electricals. It was easy to do and this 2004 trans is only $200 with 60K. For an extra $30, I could buy the front and rear seals and the valve body gaskets from Maxx and J-Mod it. The 94 suffered major heat up under that car when the fire was going and they are telling me the bell housing was a little bit warped.
I kinda believe this because one octi on the front drivers side also had a flat spot from the intense heat.
