4R70W from 2001 F150
PenGun
BC
I can't remember and search is not helping. Does this tranny fit a Gen 1? They are rare here so I might jump on this if it fits.
It is a V6 motor but I'm pretty sure that makes no difference.
I can score it for $250 I think and I'll J Mod it instead of my 93.
The V6 is a Windsor pattern so its a good 60s mustang swap
indeed. i wouldn't mind one for our cougar. even though the AOD in it has the 4R gearset already.
i also believe a member on LOD swapped a trans from an f150. and i think it has a different spline count for the VSS sensor? he is having a hard time correcting the speedo.
I have a 93 Mk 8. Pardon my ignorance, besides the 93,94 and 95 Mark 8's what other Ford models have a "swappable" 4R70W transmission for my 93? I presume the Gen 2 Mark 8's have the same transmission but would require electrical modifications only (?). How much for a rebuilt/remanufactured 4R70W should I expect to pay and where would I purchase? Thanks!
a newer style, upgraded clutch material i believe was the only major change.
everything else was just thoroughly checked and replaced as necessary.
guy did a good job. it got jmodded before i even put it back in the car and hasn't missed a beat ever.
The interceptor trans will work as well. Preferred in my opinion.
You have to have the driveshaft shortened an inch.
Found this wiki article interesting:
http://en.wikipedia.org/wiki/Ford_AOD_transmission
Also a link in the above article:
http://www.lincolnsonline.com/tech/00080.html
You guys probably already know most of this.
Pull-a-part here in Charlotte has a slew of Crown Vics...Ford explorer's etc...should be able to find one newer and would swap. Another project.
At the moment I am sitting at the "stealership" ;)twiddling my thumbs as they give me their diagnosis. It's a good bunch of guys here I just can't afford their overhead! We shall see. Thanks for your support!
From all my reading I realize I don't need to do one mod...I have the right driveshaft! I guess that would be cheating to put that in my signature!
