so i ran the car last night , the only changes from the last time were 4.10 ,tracloc and 245/55 tires
previous best was 14.60 at 98 2.18 60'
previous best in similar conditions was 14.71 at 98 2.22 60'
last night i made 10 passes cooled down and hot ,different launches etc
best pass was 14.67 at 95 2.13 60'
all of the incremental times were the same as usual
the car was more consistant , but i think it was because of the posi and better tires , traction was not an issue last night , but it was with the other gears and open dif
i'm going to run the car again just to be certain , but if i doesn't run better the 4.10's are coming out , mostly because of the cost of a new driveshaft that i have to get because it vibrates (which isn't an issue under acceleration ), oh yeah the speed limiter wasn't cutting the car of till after the traps
