jbbatten21
I have searched the boards without much success. My 97 Mark Viii has 52k original miles, but sat without care for around 5 years. I have already cleaned the tank and replaced the fuel pump as well as cleaned the fuel lines and replaced spark plugs. The car runs good, but will not rev past 3k rpms when it has a load on it. When in park or neutral it will rev freely with no problems. I already did the seafoam treatment and made sure the IMRC are moving freely. Right after the fuel pump replacement the car ran great, it would pull hard to redline through 1st and 2nd gear, but every now and then it would lose power to the point of not being able to hold highway speed, but after a 10 sec pause it would be back to normal. I checked fuel pressure and get around 34psi with the vacuum line connected and 40psi with it removed. I am at a loss on this one. Any direction on where to start next would be great.
Thanks.
Thanks.
