2002 LS V8 Part For Sale, Shocks and Cooling System Parts
Understandable, I’ll save up the money and purchase asap. Just replaced a few of the coolant system parts but didn’t do my research before starting so I’m running into trouble. I’ll be end up needing all of it before it’s said and done
These parts will only fit a 2000 to 2002 V8 non-sport. My car didn't have an external oil cooler, so the large bottom radiator hose will not with with a car with an ext oil cooler, Just an FYI.
Ahhh! Well mine is an 01 v8 sport… I just replaced the water pump lower and upper radiator hoses. Now working on vacuum hoses that keep leaking. Well thanks anyway.
Everything should fit except the lower radiator hose, you need to look underneath the car a see if it has an external oil cooler. I am pretty sure all sports had external oil coolers. So you will need to find the correct lower hose, but everything else i have in that kit should work.
Just saw where you replaced that hose anyway so that is good. If you want the parts I can just keep the two radiator hoses and sell you the rest of the kit, if that is what you want to do. No hurry on my end.
That’s great man, I’d still love to purchase all that. May take me a couple months to get the money saved up. I’ll get back with you when the time comes and if you still have it I will be glad to purchase
you still interested in the cooling parts?
I used rock auto, also little update, found coolant inside cylinder 8 rusted all to hell too. Mechanic said I will need to rebuild or replace my engine…
Cooling parts, brakes and coils still available.
I know you want to sell as an entire lot. I'm interested in all the cooling components except for the belt, t stat housing, and dccv (I did dccv last year, alum stat conversion years ago, and hydro fan / electric fan conversion so no pump and have a shorter belt) if that works.
I think I would be willing to do that, would really like someone to be able to use these parts. I can send all the cooling parts, except the belt, t stat housing, dccv, and the cooling pump since you don't need that pump either.
I sold most of the cooling parts. I have the DCCV valve, the serpentine belt and the URO Jag Aluminum Thermostat Housing. I also still have the hydraulics fan pump without the valve.
If you are interested in any of these let me know.
Still have two front rotors and pads, and two ignition coils.
Still have the DCCV valve, the serpentine belt, the URO Jag Aluminum Thermostat Housing, the hydraulics fan pump without the valve, two front rotors and pads, and two ignition coils. All of these parts are new and all are new OEM except the Thermostat Housing which is aftermarket.
I need that thermo housing good sir and the dccv valve. What would it take to get ya to part with em?
