2002 LS 5 spd Manual, Hard to Start without mashing clutch into the carpet
Lincoln LS
  1. Steve Kramer
    Steve Kramer New LVC Member
    3
    Nov 30, 2019
    MD
    I recently got this car. It is very clean, runs great, just seems to crank too long unless the clutch pedal is mashed into the floor. I have replaced the clutch safety switch, which seemed to help at first, but now its tough again. I had the computer re flashed last dealer as per mechanic recommended. Seems more noticeable when cold.
    THanks
  2. 04_Sport_LS
    04_Sport_LS Dedicated LVC Member
    3,603
    426
    Jun 12, 2012
    Somewhere around Lake Erie
    Your switch is probably out of adjustment... or you have a problem with the clutch pedal and/or mounting bracket. Something may be worn or bent.
  3. Steve Kramer
    3
    Nov 30, 2019
    MD
    ok thanks--I will check that out--I was thinking since mostly notice it when its cold, maybe a fuel pump or fuel injection issue?
  4. milehighmikey
    milehighmikey Dedicated LVC Member
    797
    56
    Apr 2, 2007
    Nashua
    If the engine is spinning then the clutch safety switch is not involved. You may want to check everything else. In order to fix it, it must be determined what is missing. Air, fuel, ignition? Have the plugs been changed? Clean the MAF sensor. Change your air filter if is has not been changed.
    • Like Like x 1
    • Steve Kramer
      3
      Nov 30, 2019
      MD
      thanks will do
    Share This Page
