2001 Lincoln LS V8 Valve Cover Gaskets Question
Lincoln LS
  1. DaleGrib
    DaleGrib Dedicated LVC Member
    677
    72
    May 14, 2018
    North Carolina
    Does anyone know the correct part numbers to the left and right side OEM Valve cover gasket kits for the 2001 Lincoln LS V8? I am having them replaced yet again so I figured I would go OEM this time if it is possible still.
  2. Jtown
    Jtown Active LVC Member
    86
    11
    Dec 24, 2018
    Cary, NC
    Certainly can get them from Fordparts.com. Pricy suckers. I just used Felpro on mine. Not a lot of miles on it yet but did yours fail (obviously yes or you wouldn't be asking)?
    I said in a previous post, Rock Auto had a closeout going on on Feldpro VC set.
    • Like Like x 2
    • joegr
      joegr Dedicated LVC Member
      19,779
      1,465
      Dec 10, 2005
      Gulfport
      Should be:
      XW4Z-6584-AB
      and
      XW4Z-6584-BB
      (Gaskets and seals)
      • Like Like x 1
      • DaleGrib
        677
        72
        May 14, 2018
        North Carolina
        Well yes one side has failed for sure but I really blame the guy that installed them. So I might chance it again with Fel-Pro as the person doing my repairs this time around is the person I wished had done it the first time around. I am gonna also have them change out my wiring harness. I think after everything is closed back up on the valve covers then I should have that harness changed out.
      • joegr
        19,779
        1,465
        Dec 10, 2005
        Gulfport
        Hey, while you are at it, you might change the o-ring for the fill tube. I don't know which one to order, I just used one out of an assortment that I have. Once the cover is off, there are two tabs to press in while rotating the tube to remove it.
        • Like Like x 1
        • DaleGrib
          677
          72
          May 14, 2018
          North Carolina
          I know that was done the last time the gaskets were changed. But knowing how bad their work was in general I will likely have it changed again. Thanks for the heads up though as always Joe!
        • joegr
          19,779
          1,465
          Dec 10, 2005
          Gulfport
          Where specifically is it leaking?
          There's a trick (make a tool) to getting the two gaskets for the inside bolts on correctly. It's easy to forget one or more of the COP well gaskets. Also they might have missed the need for sealant at the timing cover seams.
        • DaleGrib
          677
          72
          May 14, 2018
          North Carolina
          It's leaking in the back of the cover and hitting the exhaust. The COP wells are bone dry!
        • 04_Sport_LS
          04_Sport_LS Dedicated LVC Member
          3,145
          347
          Jun 12, 2012
          Somewhere around Lake Erie
          My VCG's were done at 180k... And so far no issues at 215k.
          For the filler neck o-ring... go up one size in thickness. Or clean out the groove of all oil, (brake kleen), and squeeze a bunch of RTV in it... Then wipe off the excess after the tube is installed, and give it overnight to cure.
          If they are leaking where the timing cover meets the block... then the previous mech didn't use quick dry RTV, and didn't let the regular stuff sit long enough.
          • Like Like x 1
          • 04_Sport_LS
            3,145
            347
            Jun 12, 2012
            Then he probably didn't follow the proper tightening sequence and/or torque specs.
            He might have missed an o-ring too. There are a bunch of them.
          • joegr
            19,779
            1,465
            Dec 10, 2005
            Gulfport
            I used the same size o-ring (as far as I could tell) and used RTV. I changed the VCGs a week ago on my 06 at 190K + miles. They weren't leaking (except for seeping around the filler), but I figured I'd do it now (was time to change the plugs anyway) and not have to worry about it the rest of the time I have the car. I changed the COP boots as a just-in-case, but the COPs are still going strong (changed just before 100K).
            • Agree Agree x 1
            • DaleGrib
              677
              72
              May 14, 2018
              North Carolina
              I will be sure to pass this info along to the mechanic! Thanks ! I may be wrong about where the leak is coming from so this is good info to have. The leak is very, very small! I only say that cause I have barely had to add any oil. It really only starts smoking from the leak when the car is on a hill or at a slight angle.
            • 04_Sport_LS
              3,145
              347
              Jun 12, 2012
              Ditto :cool:
            • 04_Sport_LS
              3,145
              347
              Jun 12, 2012
              The factory manual shows the proper torque sequence... And IIRC the torque value is the same as the cooling system parts... 89 inch pounds, ( I'm probably wrong though).
              I DID go through the torque sequence 3 times though, just to make sure all the bolts were tightened to spec.
              • Like Like x 1
              • DaleGrib
                677
                72
                May 14, 2018
                North Carolina
                Pretty sure you are right.
              • smegun
                smegun Active LVC Member
                139
                Aug 5, 2018
                deltona, fl
                the plug cap grommet is distinct where the cam cover gaskets are smashed down I want to try another brand or find a solution …. permetex in the grooves first ….or ? rock auto states felpro strategy is conforming that the gaskets are supposed to conform but I used an aftermarket brand that may be too cheep like the small forward seams are smashed down on the plug seals I want to try the blue ones
              • 04_Sport_LS
                3,145
                347
                Jun 12, 2012
                I think LVC's universal translator is broken.
                • Agree Agree x 1
                • smegun
                  139
                  Aug 5, 2018
                  deltona, fl
                  k your m k your D hard to find a northstar with rearwheel drive he ha serious the plug cap gasket has a ridge the valve cover gasket gets smashed you don't know if its standing up to the newer oils see oils and petroleum has different effects on rubbers and plastic felpro says conforms or molded …. im takin a chance on the blue ones this time did you get that lol
                • 04_Sport_LS
                  3,145
                  347
                  Jun 12, 2012
                • 04_Sport_LS
                  3,145
                  347
                  Jun 12, 2012
                Share This Page
