2001 Lincoln LS passenger side rear view mirror replacement....Any help or advice is appreciated
Lincoln LS
  1. AmsterDutch
    AmsterDutch Dedicated LVC Member
    936
    137
    Jul 9, 2017
    Minnesota
    The bolts on the side rear-view mirrors are held in by molded plastic ...go figure...if the plastic breaks internally the mirror will start prying back off the window ...gorilla glue worked great to reinforce the plastic that was broke
  2. AmsterDutch
    936
    137
    Jul 9, 2017
    Minnesota
    So for those of you who have to replace side rear view mirror, you must go through interior door panel, three bolts hold the mirror on car, and all three bolts are 12mm easy procedure just be careful these mirrors are all plastic internally.
Share This Page
