2001 Lincoln LS Gen 1 Workshop Manual
Lincoln LS
  1. DaleGrib
    DaleGrib Dedicated LVC Member
    738
    79
    May 14, 2018
    North Carolina
    • Like Like x 2
    • thebigguy1
      thebigguy1 LVC Member
      12
      Mar 14, 2018
      Dallas, TX
      • Like Like x 1
      • AmsterDutch
        AmsterDutch Dedicated LVC Member
        1,948
        328
        Jul 9, 2017
        Midwest
        Would like to put this in my google drive but I'm a
        ( APPLE ) guy can you upload it with something other than droid? Much appreciated if it's possible ...thanks
      • DaleGrib
        738
        79
        May 14, 2018
        North Carolina
        There is an option to Download from the top of the Page. Also that is not Android. I am a apple guy as well.
      • AmsterDutch
        1,948
        328
        Jul 9, 2017
        Midwest
        Got it! Thanks! Had to switch from Ipad over to macbook for some reason
        • Like Like x 1
        • DaleGrib
          738
          79
          May 14, 2018
          North Carolina
          I had searched a lot of sites for sharing the pdf's that one had seemed like the best, it was fast and easy.
        • Tony obrien
          Tony obrien New LVC Member
          7
          May 30, 2020
          Charlottesville
          Thank you very much. I have a 2002, if you happen to have that manual as well. I gather there are some minor differences.
          • Like Like x 1
          • DaleGrib
            738
            79
            May 14, 2018
            North Carolina
            Here is another post that has them all Lincoln LS Workshop Manuals
          • smegun
            smegun Well-Known LVC Member
            200
            Aug 5, 2018
            deltona, fl
            yea i like this you know the other manuals that is the denou and the older one i have is not as nice ...that is it clearly states to remove a head you need to remove the motor ... here in this manual it is listed in the in vehicle section and doesnt mention having to remove the motor at all .... well i was looking at the gen 1 and 2006 manuals originally and found simularities about removing the engine first and asking if anyone had removed a head with the exhaust manifold attached it seemed sketchy at first .... anyone want to comment on the proceedur ...duh like i had the whole front of the car off to inspect primary timing set but couldnt see a clear path to take off the ex manifolds and get to the head while in vehicle
          • smegun
            200
            Aug 5, 2018
            deltona, fl
            i did a feeler gage job and a leak down and i think im in spec but i wanted to take the heads in for a pro inspection and possible retrofit befor i put it back together im a believer there aint much room
          Share This Page
