2000 LS Amp Connector
Majdelboy
Ottawa Canada
I have a 2000 LS and I am looking for the connect for the AMP which is in the trunk. The connector is the one for the rear speakers, I have the one for the power connector. When I bought the car the previous owner had a another AMP which he took with him before he sold me the car.
Do you know where I can buy this connector, or if anyone knows the pin out for the 6 pins. Any help would be greatly appreciated...txs.
The trunk connector (on the drivers side) is number C465 and the sub audio uses these pins:
1 = yellow/red: switched hot
3 = shield for low level audio signal
5 = red: constant power from battery junction box fuse F418 (20 amps)
7 = white/red: low level LEFT audio signal
8 = grey/red: low level RIGHT audio signal
This is the power connector pin out, can you give me the pin out of the connector to the speakers, the connector has 2 pins and then 4 pins (in a line). I assume the 4 pins are those for the rear speakers and not sure what the other two pins are for...txs.
