capri83rs
Hey, as stated I have a 95 Mark VIII LSC. The car has been through a lot before I got it. I am absolutely in love with this car, but honestly, I'm starting to think it's not worth sticking with. Since I have had it, it started running rough. Last year it would "die" while driving down the road. Sometimes it would actually die and sometimes it would just cut out for a really long time (good few seconds) the get power again. Then it started having a miss. So far, I have changed one coil pack, and the wires and cleaned the throttle body. I had it running pretty good. Then last winter, it started running rough again, but only when it was cold and started. Sometimes, the choke would not kick in so I had to sit with it for a few to keep it running. Then one day, I get in and pull out of the drive and it starts an extremely rappid miss and just falling all over itself and had pretty much no power at all. So I turned around and parked it. Every once in a while I would go out and start it. It would start and idle smooth, but if you gave it any gas at all it would start the miss. Then after it sat for a while, it wouldn't start at all. We got it to where it would start now, but wont run but just a few seconds and die again. The fuel pump is good or is working at least. I have taken it to a mechanic that I trust as I do not know a ton about fuel injected cars and all the computers. He hooked it up to his computer and his computer went nuts he said. All the meters on his computer went crazy, fluxuating a ton, and it wont allow him to run the self diagnostic (at least I think that's what he called it). And when he turned his computer on, hooked up to the car, the blower motor for the vents came on. He said that was not normal at all. He said he has never saw anything like it. He honestly said he wasn't sure what was wrong with it, but his best guess would be the computer. So I ordered a computer and that did not fix it. So it's still broke.
Now he is saying that he is still not sure, but don't really think the cars worth fixing (I almost agree). It's not in the best of shape and has a lot of miles. But as I said, I really like it and would love to get it going again. I really don't want to junk this car, so I figured I would put a post on here and see if anyone had any ideas whats wrong with it. So feel free to chime in, any help would be greatly appreciated! Thanks in advance!
