joegr
ok same prob but mine started today. the driver side is set at 60degrees and so is the pass. but the driver is blowing out ice cold like it should the pass and the other hand is blowing hot hot air. a/c button is on too. i ended up goign home and then left again about hr later and well it is just fine bothe sides ice cold. Any ideas what this could be ?? im really confused![]()
Yes, getting heat when you should get cold air is a really clear problem. So far, it has always been the DCCV that needs to be replaced to fix your issue.
