Just finished a mock up of my own cold air induction. I have to get the air tube chrome plated and the KKM mass air unit polished, but I wanted to see how everything fit first. Heat shield is from a 3.9 K&N filter pak kit.
Looks great!!! I would like to know what you did with the two hoses that come from the under the engine cover, that connect to the valve cover?
Hows the idle? Is it rough or jitterie?
Thanks for the info...I was going to use some spare T-bolt clamps, solid stainless bands, but didn't have the correct sizes....another order to Summit on Monday.Looks real nice Nick.
If you want an even cleaner look invert your hose clamps and use a small ratchet and socket to tighten them back down while the worm gear bolt is under the tube. It hides them and will give a cleaner appearance.
Good work.
what material did you use for the heat shield it looks great, was is difficult to shape it the way you wanted....
hey Nick, where do you buy the couplers? i don't really like the ones that came with my CAI and want to get better holding ones. the blue rubbery ones just don't seem to hold tight enough and seem to move after a while due to heat and the car movement. thanks in advance
That looks great!!!!! Now how about the idle? Is it the same or does it vary alittle when just at idle in park or drive?
what material is the tube and where did you get it
