MMAFIGHTER121
possible solution to check next:
since I'm also having weird troubles with the Cruise engaging, it lights up then back off almost immediately as if I hit the brakes.. I'm wondering if the Lincoln has a switch in the brake pedal that interrupts power to the TCC solenoid when they're applied, like a lot of cars do, and if that has gone awry, or a brake sensor of some sort is the issue.
