Science Abuse
I like playing with tire sizes, and apparently this is frowned apon by the car.
Can this feature be disabled entirely?
The only thing is I believe your traction assist works with your ABS, so you might have to be careful what you do and what wires you cut so you don't mess something up with that. You might find some answers if you do a search, or, since you've already asked the question, maybe someone can help you.
CAn it be disable din other ways besides turning it off at the message center?
I pulled the fuse to kill my ABS pump, and it turned off the TC, along with the speedo
so, jumping those pins would (in theory) make the TA-Off the default setting?
Ohhh you've got Scott's old car! Cool!
None of those things are needed to drive like a Hoon.![]()
The search function on this site isn't very useful at all. I found many threads which mention either Traction or Control, a few that mentioned both, and none that said anything about disabling it permanently.
