I am in desperate need of a good counseling session or I am going to 12-gauge my car! After reading many posts and researching my heat issue all of the symptoms and previous posts pointed to the DCCV.
I have a 2000 lincoln ls v8 but it has a 2003 model engine. After taking 12 hours today (because I am not a mechanic and this was my first time ever working on a car) I removed my DCCV cleaned per tireman's instruction document he sent me and then replaced it all back together. I bled the system, idle for 3 minutes at 2000 rpm and bam I had heat!
After the heat was blowing through vents at 90 degress I switched it to defrost to see if it would blow heat in the past it would only blow cold air. WOW! After the car sat runing for at least 5 minutes I has heat. I was pumped and proud that I managed such a task.
Next I set the temp to 75 degrees per instruction sheet I had and it decreased a little but still was warm. I turned the car of and let it sit until I finished replacing air breather.
Got in my car and started the drive home about a 12 minute ride and guess what. Window fogging, no heat when I placed on defrost only cold air which did clear up the fogging but clearly it is back to doing what it did before. Lukewarm at bes ton the heat. When I press the aout button on wvwn at set temp of 90 the ac button lights up. I manually turn it off and push the floor/defrost button only to get lukewarm to a cool air.
I have performed the computer self diagnostic and get all 8's and I can hear the doors open and shut during the testing. Also the heater hoses are hot all the way into the firewall.
I need some help what is next?
