Headlight polishing; has anyone tried coating them?
Science Abuse
Cincinnati
Polished headlights always fog back up, I was wondering if anyone has tried coating them with something to protect the oldass plastic from oxidization? Be it spray Polyurethane or a marine coating.
Crystal View headlight restoration kit from Wally World or Autozone. It's about $20, comes in a foil pouch and has a quick drying clear agent that is applied as a last and final step that replaces the old uv coating. Better than any kit I have tried yet simply because most other kits are inferior because of the reason that you mentioned. Polishing is polishing and not a long-term solution like the Crystal View kit. Try it and be amazed. I was. :)
The Turtle Wax kit works well too. It comes with 4 sanding pads, plastic polish, some kind of spray agent (????) and a clear agent that you apply at the end. Costs about 10 bucks. The clear agent is a one time use pad, but you definitely won't use all the plastic polish in one sitting.
I just put about 2 coats of good wax. Works quite well for me and my LSC housings, and countless mustang lights I've done
I used Optimum Opti-Coat 2 sealer for the projector project I'm working on. A couple drops is all it takes. Its a very hard sealer that can only be removed by polishing etc.
-Scott
+3 on waxing. Its luke clear coat on paint. The lenses have some kind of uv ray protectant on them. Use wax after polishing them
+1 used the turtle wax kit after the powerball from mothers. i just hadto have the attatchment for the cordless, they started to haze after3 months, saw the turtlewax kit with sealer used powerball with mothers, then turtlewax, then used lens sealer. now ive got light apart toying with projector idea,and another,including custom bumper,just have absolutely no money,none, i'm so broke i cant pay attention!
After the initial sanding a 2-3 years back all I have to use now is Mothers plastic polish and a drill attachment to buff it out. Did mine last summer and they still look great. I'd prob pass on doing them this year but ya gotta maintain them.
The SEM clear cures either with the uv light or about 10 minutes in the sun on a nice day. Just sand the old coating off with 1500 wet paper, blow it dry and clear.
I had a guy do my headlights and he sanded them down (not sure of the grit) then clear coated them with what they use on paint and it looks great. I couldn't believe it when they went from being cloudy from the sanding to perfectly clear.
That's what the body shop did to my driver's side headlight and 4 years later that headlight is still clear as day and looks new. And that's exactly why I believe in clear coating as a last and final step when reconditioning headlights. Polish will wear off, clear coat stays there for years.
Went with the Turtle Was kit, thanks for all the recommendations.
I advise not opening that sealer patch until you've buffed all of the lights you're going to buff. I managed to do 6 lamps in my stable instead of just 1 or 2.
First pic is just the buffing, last is with the coating.
