Shock bolt
fastmark1993
Edmonton, Alberta
Bottom shock bolt front suspension, got it to line up on the left side of the control arm but not the right I tried jacking it up, didn't work. Any ideas?
If your worried about your alignment you can take off the rear strut rod nut to allow more movement in the lower control arm
I was told you have to have both sides jacked up as level as you can get it to relieve stress on one side. I went thru this when trying to unbolt my shocks.
