Cooling System Double-Whammy or Domino Effect
Tru-Blu
Lambertville, MI
Of course it had to be right after my extended warranty expired - but it's still pretty much my fault. I'll explain -
About 6 months ago while driving to work, the temp gauge immediately spiked to max, kicked off the Check Temperature warning (and associated P1299 code of joy), but did not put the engine in limp mode. I was able to get to work fine and when I drove home that day, the car was completely fine. I put my XCal scanner on it to confirm the P1299 code, and cleared it - thinking that if it happened again I would take it in since it was still covered under the extended warranty. I figured it was just an air burp in the system since it never went into limp mode and actually came back to normal temp while I was driving.
Fast forward 3 months, and I'm driving home and the car spikes again but this time it does go into limp mode. I pull over, shut it down, wait about 3 minutes while it burps and gurgles, and then restart it. Starts and goes to normal temperature range. Car was fine again until this past week - which was about 2 weeks after my extended warranty expired.
Last week, the car spiked about 3 times, and got to the point where it would go into limp mode every time it happened. Pulling over and allowing it to burp the air out worked until the last time, where the temp stayed up and I truly had to limp home.
At this point, I was suspecting thermostat so that's where I started. Last weekend, I put a new thermostat in. When I pulled the old one out, it was confirmed as it was stuck in the closed position. So, after breaking and replacing the radiator drain plug, I put everything back together with no leaks or issues. I was able to bleed the system in just 2 passes, and took the car out for a drive. Here's where the next issue reared it's head.
The air that was coming out was WAY too hot. I started adjusting climate controls, and it didn't make one bit of difference. So, the logical assumption was the DCCV. I checked the fuse, and unfortunately it was fine. I don't know if the valve is stuck in the open or closed position, but I'm assuming that it's stuck in the closed. I also don't know if the thermostat caused the DCCV to go bad, or vice-versa but I guess it doesn't matter.
So, to make a long thread longer, I'm just asking for confirmation that my suspicions are correct. I'll start looking back through the threads for part numbers from rockauto, partstrain, and calling Maxx. I'll probably replace the upper hose while I'm at it since it's a high-risk part for failing too. Don't know if I'll do the Degas bottle or not.
I've looked through a bunch of threads, and I'm thinking that this is the best way to go - as opposed to getting a clue and taking it in under the extended warranty the first time the code kicked out.
Thanks,
Tru the Clueless
Yes, it's probably the DCCV, but it's stuck or staying open, not closed. Open is heat, closed is no heat.
Tru might as well do the degas bottle too since you'll already have to bleed the system again...
+1 for degas bottle. Just popped my new one in an hour or so ago and the old one was an ugly sight underneath.
I'm at 57K for my 2006. You guys are speaking wise words - guess I'll bite the bullet and do the other 2 of the Coolant Big 3!
Since I'll be getting the Degas Bottle too, I'm thinking the best sources would be RockAuto or Maxx. Are there other sources for it?
Thanks,
Tru
Thanks Marc. Ironically, the DCCV started working again yesterday. I may wait until it consistently fails before I rip it apart again.
If it behaves anything like mine when it went bad, you have at least the rest of the summer to ignore it and use the ac. LOL. Although, I did have one day in the summer when the heat stuck on for about 45 seconds. LOL.
My wife's LS did same thing, that DCCV will not fix itself! Hers worked, didn't work with a few days or a week in-between, but finally stuck in heat mode. Thermostat did same thing as yours. I took to shop, independent, had all coolant parts replaced but radiator and fan. Over $1,800. I had just finished all COPS, plugs, VCGs, coolant sensor, cleaned MAF and replaced TPS & PCV. Seems like 80k miles everything broke. No problems until then. Bought 1st 1 off dealer lot. Should have waited for the V8 LSE.
1998 Volvo C70 2.3 Turbo, Auto, All options, 34k miles, MY TOY!
2000 LS V6 Auto 83k now, wife's toy.
My DCCV went while i was moving to Atlanta. We were in the mountains of Tennessee, and all of sudden all we'd get was full heat. That was fine until we got into Georgia and it was 95 out. We couldn't even drive with the windows down, it was like sitting next to a hair dryer. Then the thermostat went about two weeks later.
