Chris_Murder
I have a plan to add an oil supply hose for an upcoming modification to where the factory oil level sensor currently is. I have no use for the factory sensor since my mark motor isn't in a mark viii and it isn't hooked up to anything anyway, currently it just plugs the hole. I'd like to replace the sensor with a male threaded fitting so I can hook a oil supply line directly into the pan without having to tap another hole. Can anyone supply me with the correct thread size and pitch?
For example the drain plug size is 14 x 1.50.
Thanks,
Chris_Murder
Thanks,
Chris_Murder
