Right on the Mark
Please can I just get an easy answer? I don't want to break anything. I need to remove the clear outer dome then the bulb. How to do this 1-2-3 please? Thanks
Yes, it twists off. Twist counter-clockwise to undo it. Here's the thing: The dome has a rubbery seal that sticks to the headlight housing over time and you can break those very fragile tabs when you get too aggressive and it finally breaks loose. If it doesn't twist off with gentle force, then I'd recommend using a razor blade to break the seal as much as possible, then gently twist it off. Use some silicone lube on the seals when you put it back on (assuming you're replacing it).
EDIT: I re-read your post two up from this... I've never seen one where you push the tabs in. That must be an older version. I know they went through several iterations of the housings.
