Wrecked 03 Cobra Being Parted Out near me
The engine....
Seriously though, you might want the rear shocks if they're not high-mileage, or f'ed up.
Attach the boost a pump to our :q:q:q:qty HVAC blower motor and let me know what happens.
The motor with S/C is $3300. That is just the motor. No harness or computer.
You don't need the 03 computer or the harness. You can modify a gen2 Lincoln harness and buy the extra connectors you need from Ford for >$70, you'll need the vacuum and the power harness, as they are the only ones you cant do without. But it's an 03 that's most likely a tick motor and high raped mileage.
Well, I went and took a look at that Cobra. I scored the calipers, rotors and front spindles for $140 :D. I am now have way complete on a hub swap now.
Gman, get the pulley bridge and all that super charger stuff, altenator bracket and all. You will need all those parts so you don't get nickle and dimed to death trying to get all the parts for the charger swap.
poor baby. if those seats are in good shape and there is a good price id pull them and make some pretty nice green
Originally Posted by 99riocobra View Post
i will first start off by saying please use that brilliant thing they came up with a while back called the "search" function. please! with that said, here's a list with some part numbers, and then the list i made on my own that's more "generic" but sometimes easier to interpret....
1.) 2R3Z-6312-BAA Crank pulley /Harmonic Balancer
2.) 2R3Z-6C254-BC Supercharger Crank drive pulley
3.) 2R3Z-8678-BA Pulley w/mount Replaces stk alt. Pulley
4.) 2R3Z-8B603-BB Pulley bridge assembly for S.C.
5.) 1L2Z-8678-AB Idler pulley,timing cover LH side
6.) 2R3Z-6D080-BC Timing cover
7.) 2R3Z-6020-AA Timing cover gasket LH side
8.) 2R3Z-6020-BA Timing cover gasket middle
9.) 2R3Z-6020-CA Timing cover gasket RH side
10.) 2R3Z-10A313-AB Upper alternator bracket
11.) 2R3Z-10153-BA Lower alternator bracket
12.) 1U2Z-14S411-TA Electrical connector (alt. to harmness )
13.) 2R3Z-6B209-AA Tensioner on timing cover
14.) 2R3Z-8260-AB Radiator hose
15.) 2R3Z-8A593-AB Radiator hose
16.) 2R3Z-8K576-AA Radiator hose
17.) 2R3Z-8286-AB Water cross over pipe
18.) F8ZZ-6881-AA Cobra oil cooler adapter
Note: Use your stock gasket from your adapter or a leak will occur
with a Cobra gasket!
19.) 2R3Z-6A642-AA Cobra Oil cooler
20. 2R3Z-9002-AA Cobra fuel tank
21.) 2R3Z-9H307-AB Cobra fuel pump
22.) 2R3Z-6F066-AA Eaton supercharger & inlet / T.B.
23.) 2R3Z-9424-BB Lower intake
24.) 2R3Z-6K775-BA Garrett factory intercooler
25.) 2R3Z-9H486-?? Intercooler to S.C. gasket
26.) 2R3Z-9A758-AA Cobra throttle cable
27.) 3U2Z-14S411-JUA IAT sensor connector
28.) 2R3Z-9H308A-?? Intercooler pipe to heat Exchanger
29.) 2R3Z-6K683A-?? “……………………………………..”
30.) 2R3Z-6K683B-?? “…………………………………….”
31.) 2R3Z-6K683C-?? “…………………………………….”
32.) 2R3Z-6K683D-?? “…………………………………….”
33.) 2R3Z-6K683E-?? “…………………………………….”
34.) 2R3Z-6K683F-?? “…………………………………….”
35.) 2R3Z-6K683G-?? “…………………………………….”
36.) 2R3Z-8501-AA Ford / Bosche water pump for intercooler
37.) 2R3Z-9L440-?? Factory heat exchanger
38.) 2R3Z-8A193-?? Heat exchanger mounting bracket
39.) 2R3Z-6C693-?? 2each bracket clamps
40.) 2R3Z-9H308C --?? Lower manifold to intercooler water adapter
41.) 2R3Z-6F089-?? EGR Valve
42.) 2R3Z- -?? EGR Tube to exhaust manifold
43.) 2R3Z- 8N500-?? Water pump intercooler bracket
*** #29-35 are intercooler lines
My List:
1) all intercooler lines and elbows
2) intercooler fluid reservoir
3) heat exchanger and mounting brackets
4) intercooler
5) intercooler pump and mounting bracket
6) intercooler cap(mounts to front of lower intake and has 1 in and 1 out intercooler line)
7) intercooler pump wire pigtail
8) timing cover
9) every single pulley except AC and water pump
10) supercharger pulley bridge that a few idlers mount to
11) both belts
12) lower intake
13) IAC valve(that thing that sits on top of the plenum/elbow)
14) supercharger and plenum
15) alternator and both mounting brackets
16) alternator wire pigtail
17) throttle and cruise cables
18) throttle/cruise cable bracket that mounts on the blower
19) the whole vacuum assembly and the stuff it all plugs into on the driver side of the blower
20) main feed line coming out of PS reservoir(the bigger one going to the pump)
21) return PS line(the other smaller one out of the reservoir) as well as the sections that "T" to right next to the radiator and to the booster
22) pcv valve and hose
23) EGR valve
24) EGR tube
25) oil cooler
26) all of the soft radiator hoses:
a) upper hose going from the crossover tube to the radiator
b) the big long one going from the middle of the crossover directly down and goes into the thermostat
c) lower hose going from lower radiator to t-stat(about 10" long)
d) hose going from oil cooler to t-stat(about 10" long also)
e) smaller diameter hose going from bottom of coolant resevoir to t-stat
----> the last hose (e) may not be needed to swap, but i did anyway
27) coolant crossover tube(hard U-shaped tube going from head to head)
28) fuel rails(i'm not sure if the pressure sensor on the driver side rail is the same, but we swapped that too)
29) boost bypass valve actuator(circular thing with on the rear driver side of the blower)
30) gaskets:
a) intercooler cap(mounts on front of lower intake)
b) plenum to blower(if you get a supercharger with the plenum on already, then you don't need this)
c) throttle body to plenum
d) IAC valve to plenum
e) EGR valve to back of blower
f) timing cover(3 parts to this gasket, and they are all sold separately)
g) supercharger to lower intake(this one can be reused if you can het the original from the guy with the 03)
h) you can also use your original lower intake to head gaskets. you just have to cut off two small tabs(one on each one). you'll see when you try to line them up with the 03/04 lower intake. no big deal at all, takes 3 seconds.
-----> you'll also need to do something for fuel. stock 03/04 injectors are fine. you can run a BAP on your stock pump, or swap to the 03/04 tank and dual pump setup too...
Nope, my name is not rio99cobra. :D Yes, it was copy and pasted though, didn't want to take credit for something I didn't post.
