Jkhoyt
First, I wanna say I usually work on older GM cars, so some of the ways things are done on this car confused me ( Jet pump, cooling system, etc ). This website has had some great info to help me out while working on my friend's 2000 LS V8. It has a little over 115k on the odometer, replaced the degas tank and did the VCG and 5 of the coils in the last year. It has had a code for one of the cats for over a year now, I'm guessing from the oil before the vgc was done.
Just over two weeks ago, the car starting idling rough, almost as if it had a nice cam in it. Checked the codes, came up with a P0174 System Too Lean (Bank 2) in addition to the cat. A few days later, the car started a thumping sound ( almost the same as when I heard a v6 running on 3 cylinders on time) and died. Wasn't able to start it again. Car just turns over. What I've done since :
Checked battery charge ( good )
Checked all fuses and relays, swapping them out to make sure they were good
Cleaned IAC, throttle body, and MAF
Checked for vacuum leaks, couldn't find any
Checked EGR as well as I could considering where it's located, it looked in good shape
Fuel pressure was very weak, changed filter ( on a side note, it might have been the original filter on the car. The previous owners didn't seem to do much in the way of maintenance, there's no evidence of any accident/repairs, and there was paint overspray on the filter ). When I dumped it out, a semi-solid sludge came out. Still weak fuel pressure. Replaced fuel pump, good fuel pressure now.
Checked spark, all of them good
Checked injectors, they are spraying
Tried starting without IAC connected, nothing
Tried starting without MAF connected, nothing
Tried starting giving it gas, the only difference being it sounds as if it's almost trying to start but only if I press the pedal to the floor. Other than that, just cranks
I'm pretty certain that covers it. I've read quite a bit about the timing chain, secondary chain, tensioner, etc, not going to take it apart to take that. Any other ideas/suggestions on relatively easy things I can try/check?
It's getting spark, fuel and air. Kind of at a loss of what else to do other than tell them to take it to the dealer. Any help is appreciated!
