Need Mark viii ballast info
dbleb88
Haverhill
I recently purchased a new Glitch ballast from a member that he had purchased from Glitch but didn't end up needing. The only problem is he doesn't have the directions and I understand that Glitch has been ill so I have had no luck contacting him. Does anyone have a copy of the directions to email me or have any other suggestions. I am a recent newbie to this site but sofar you people have been terrific. Thanks for any help you can give me. Bruce
I have a set I will try and find and scan them in for you. Hopefully you will see them today if all goes good.
glitch ballast has 5 wires, two large white GTO wires obviously go to the wire that feeds your neon, the two white wire on the back of the housing, the other wires are black for ground, and i believe red and blue, cut the plug off your stock ballast, and hook black to black, red to red and blue to whatever the last wire is on the factory plug i think its green.
