I’ll throw a few things out here based on my past career.
Those chamfers had to be on the pads when installed, if that is what you are talking about. They look to be about a 25 or 30° chamfer, physically impossible to have worn when installed due to the physical geometry within the caliper assembly.
Chamfers are misunderstood in the aftermarket and general population. They are not there to provide a lead-in but are used to alter the width of the pad as to not achieve a natural harmonic to the rotors nodes. If you tap on a rotor it will produce its natural frequency, along with sympathetic frequencies. As an example it might have a dominant frequency of 5k Hz, and sympathetic frequencies of 10k and 15k. If you look at a laser image of the rotor these vibrations show up making the rotor look like a wave washer. And if the pad width bridges the peaks of these nodes, noise can occur. So if this happens to be one of the many reasons that noise occurs, then altering the width of the pad eliminates the issue.
This works with the production setup as the pads and rotors are static from the same supplier sources, but in the aftermarket things change. The aftermarket rotors will have a different frequency as no aftermarket company tries to match the OE rotor suppliers’ vanes, vane count or rubbing disc thickness, so you are dealing with a different natural frequency. And I’ve never found an aftermarket pad company to exactly change the chamfer grinding equipment on the production line to match the OE. They will just make a “lead-in” edge.
The natural frequency of the pads also changes as it wears, and sometimes you can get away with the tapered chamfer you are used to seeing, but in some cases you need to maintain the pad width, such as these pads on the Ford Superduty. Ain't no "lead-in" here.
Noise insulators attached to the backs of the pad steelbacks are also highly refined at the OE level. Some are single constrained layer and other double (layers of stainless steel). They can also be what are known as “double stick”, where there is a secondary silicone adhesive backing uses to attach the pad to the caliper fingers and pistons. Companies such as MSC develop the noise insulators based on the frequency of the noise need to be abated. The viscosity and thickness of the silicone adhesive is altered to achieve this at the temperatures that noise occurs in. As the temp goes up, the silicone changes its viscosity meeting the requirement.
Aftermarket insulators are there with a hope and prayer that they will do something. No aftermarket company spends the money to develop a specific insulator for an application. And the OE product is sanctified with the OE contract, not that it matters as brake noise is also dependent on the friction material compound, both by its friction level, weight and porosity. So what insulator works with one friction material compound may not work with another, or it's different geometric shape (chamfer).
Using the aftermarket “Disc Brake Quiet” is really a poor attempt at achieving what the silicone adhesive does, although in some cases it works for a time. Another approach is to use what many of the Asian manufactures like Honda and Toyota do, using a moly filled viscous silicone grease on the backing plates to prevent the pad vibrations from transferring to the caliper, caliper bracket and knuckle, another source of brake noise transmission. It really depends on the vehicle.
It’s hard to tell in these pictures but while the pads look shiny, I don’t think they are glazed. Below are examples of glazed pads from a test.
Glazing occurs when the organics in the friction compound vaporize and deposit and the rubbing surface requires a good amount of heat. With a higher organic level at the rubbing surface, you generally develop a lower level of friction, but no so much noise. The sanding of the pads and rotor surface does remove the glazing, s will about a dozen or two of low temperature brake stops, but the reduction in noise is generally due to the rough pad and rotor surfaces now having less brake friction now that they are “green”, transferring the work to the opposite axle. Once the pads and rotors are smoothed from braking activity and friction material transfer to the rotors surface re-establishes (which is normal), the friction returns and often so does the noise.
These pads may be normally shiny due to their density and lack of porosity. We would alter a pad formula’s porosity during manufacture to reduce noise development, but with rotors that have slots you need the denser, stiffer pad to prevent the friction material from wearing excessively as the slots wipe across the pad rubbing surface, basically shearing off material.
