iam sure you've heard this 100 times
I bet there are mustang or other car pans out there that would fit. You would have to have matching pickup just to make sure it matches pan. You just would not get the 1 extra qrt kick out we have. The kick out is not needed really just a nice extra. Pan makers like Canton and such could hook you up with a pan right now I bet. Also on the cheap a Ford one. Peeps on here that have put Aviator,Terminator engines in there marks did you put mark 8 pan on?
You will learn there are lott of pats no longer available for the Marks. Not the end of the world. Keep reading the forumns.
Most (if not all) pans are not shallow enough to clear our K members. I know a guy that recently tried one from Summit and said that it didn't fit because the shallow part (can't remember at the moment if that's the forward or rear end of the pan) was too deep and precluded installation...
iam hoping it fits, i was thinking that last night knowing the luck i have ill wait all this time to get it and it wont fit lol fingers crossed........
if no fit ill be shipping a used one across the states it looks like
are most parts for marks hard to get or just certain parts? anything else that people are having trouble buying?
also whats the best exhaust option, ill be getting mine fixed when oil pan is done, should i make it true duals or anything else to keep it a daily driver but add more power or run better? or just leave it stock and do performance mufflers?
just got back from the garage becuase guy phoned saying thier not sure if it will fit now :mad: he took some measurments but its not looking good
ok thanks guys but i couldnt wait and found a pan here up north in ontario, i needed it asap and a local shop found one,its going in first thing in morning, i was getting so worried that car would be sitting for awhile and id be riding a motorcycle till snow flies
Now that wasn't all that hard was it?
lol i had to pull out all the contacts and so did the guy at the garage, just happen to get lucky and got one off a mark that was just scrapped days ago
just went and checked it out, dropped car off it looks fine, had better look at these oil pans and wtf there ridiculas lol dont understandwhy it had to bemade so complicated just need to have cut out and some bracing on k memeber and you can use alot better pan design, told them i want to keep my old pan to see if i can fab a new one just for fun
