can someone spoon feed me please
BAD97LSC
Palm Harbor FL
its late and i dont want to go outside and look, i know some have just done it so maybe its fresh in your mind. i need to know the bulb numbers and how many of each in a gen 2 interior, i know under the dash are two 194 bulbs, i need the dome light number, the 2 map lights in the dome light, the rear reading lights and door panel bulbs, i am gonna order all led bulbs for inside. thank you!
Here it is. I just don't know how many of each.
Straight from super bright led
Ash tray [194]
Back up light [3156]
Brake warning [37]
Check engine indicator [37]
Directional signal indicator [37]
Dome light [906]
Front sidemarker [168]
Front turn signal [3457A]
Glove box [194]
Hi-beam indicator [37]
High mount stop light [3157]
Instrument-general [194]
Instrument-general [37]
License plate [168]
Map light [168]
Map light [912]
Parking light [3457A]
Rear sidemarker [168]
Rear turn signal [3357]
Seat belt indicator [37]
Step/Courtesy light [168]
Step/Courtesy light [89]
Stop light [3357]
Tail light [3357]
Trunk/Cargo area [912]
Under hood light [912]
I like that you copy things I do, I won't feel so bad when I copy your new nose
sorry jeremy but you werent the first to do led's and if i was copying you, i would go stove my car into a pole!
