ChrisTheBest
just gotta remove the upper radiator hose, and the dccv is right under it, just a few bolts and it comes off.
Partstrain.com get it for 46.** with free shipping using coupon code: PTCART
Brand: Metrix
PART # W0133-1599312
Good luck!
Is that for Gen 1 also?
I know partstrain got it to me in 2 days. thats fast for free shipping. Good luck changing it out its a PITA. I just did mine took my 3 hours.
It varies somewhat by generation and if it's a V6 or V8. In any event, there's not that much to it.
Drain coolant
Remove whatever is in the way. (Top hose, aux cooling pump, ...)
Replace DCCV.
Reinstall whatever you moved out of the way.
Refill coolant.
Bleed air from cooling system.
Just replaced the DCCV, and the Upper Radiator Hose last night, and my climate control works perfectly now!
The only problem i had was trying to find the coolant bleeder i still dont know where the hell it is, the only thing i was able to find was the heater bleeder because that was in plain view next to the brake fluid reservoir
ok cool, through the tech articles it shows a second bleeder, i thought that was wrong.
Brand: Metrix
Good luck!
