turn_on68
I'm having a drive Train loud noise? It sounds like a metal on metal rubbing when driving down the road. Wife said to her it was coming from the left rear. My first thought was rear wheel bearing. I put the car in neutral and turned it off. I jacked the left side up and tried to spin the wheel. Well it still turns the rear end gear plus I can't spin it fast enough to see if it is the bearing. I need to replace all LCA's and associated parts. Could the noise be imparted to the frame because the front end ball joints and so on are worn out? I did notice when trying to turn rear tire that there is about 1/2 inch of play when you rock the wheel forward and backwards. Not side to side. I am just at a loss as to where this noise is coming from? How hard is it to replace the rear bearings?
