Dashes
Sapperfire
Waco
Does anyone else's dash do this? And has anyone found a decent way to fix/hide it?
Not mine. But I don't have a blk int or live in TX. Assuming it's heat related.
looks like some warpage going on.you might try some black silicone and fair it in there real smooth. otherwise go to a reputable interior shop and ask what they can do.
I think it is the heat. What's happening is the adhesive of the vinyl foam pad is separating from the dash frame. Once this happens, there's no fixing it. Other than swapping dashes.
Looks like the rubber on the airbag face is sagging. I suppose you could remove the airbag and put something behind it to prop it up like some foam or something and glue it in place and reinstall it
Glue a bunch of nails behind it to prop it up. That way when I piss you off you can just aim for a tree. :D
He's way ahead of you. He's already put nails back there. That's why the airbag is starting to sag.
I've seen mexican do this mod. They put a carpet over the dash. That's a good mod to hide whatever that thing is.
The dash foam is lifting, there's no glue under it where the airbag is...I tried pulling the airbag out today...but it was hot and I lost interest
FAIL
mines been like that since I bought it 4 years ago it eventually stopped bothering me.
