Door Isolator - "dome overide switch"?
Long_Island_LS
Long Island
...hey guys, wondering if any of you wiring experts can help me here... im curious if its possible to isolate the door trigger on all four doors with a single rocker switch. I have the viper 5900 alarm installed and they had to use a relay to prevent the "false alarm trigger" from the computer every 30 minutes - im sure your familiar with this problem. I have that diagram for the relay, im just wondering if there is a way to completely isolate the door trigger with a rocker switch in effect creating a dome override switch that would prevent the lights from coming on when a door is opened. Any insight would be excellent. Thanks :D
Well..... The trigger is located in the latch mechanism....
...any ideas where those wires go? ...i figured i could isolate each door individually, but that would be kinda pointless... they all have to meet somewhere and plug into a module that could notify the main computer that a door was open... i just wish i knew where that was... :/
interior light override
Gen 1 LS....The door ajar signal remains separate from all 4 doors(they don't connect to each other), the 2 rear door ajar signals go to the REM(C420c pin 16 black/orange wire & C420d pin17 black/green wire) and the 2 front door ajar signals go to the FEM(C201f black/yellow wire & C201e black/blue wire). If your aftermarket alarm is getting it's signal from the interior lights, it would be easier to add an on/off switch to the interior lights as they all have a common ground signal controlled by the FEM (C201f pin 12 orange wire).
