zmt325
i have purchased one of those walmart r134a cans with a gauge on top. i put about 2/3 of a can in, it read good pressure on the gauge like 35-40 psi but the compressor did not kick on
so I jumped the low pressure switch that is on top of the ?condenser? (the can looking thing) the compressor kicked on.
i let it suck the can dry. now when the compressor is running it reads 0psi when i pull my jump wire and turn it off the pressure reads in the red
also the compressor cycles for like 5 sec max and then cuts off when plugged into the lpss. I can watch the gauge jump from high 100 psi to almost 0 as it cycles
so wtf is going on is the static pressure of 100 psi normal?
I feel like I need to put more in it, but 100 psi scares the :q:q:q:q outta me expecially when the gauge says WARNING on it at 65 psi
