Thanks laser for the HVAC. Works perfectly and it solved the issue of my ac fan blowing all the time. Very happy about that. I'm guessing the last HVAC unit was from a gen 1.
Though that was only half the problem. One of the problems was the AC wasn't blowing hard out of the dash.
Since summer has started I've started using the AC at night and I've noticed that the car will definitely loose power when I turn on the AC. Though it doesn't loose power just once. It does a kinda stutter thing where the car will slow... then speed up again.. then slow. So maybe compressor is going bad?
I talked to my mechanic and he said that the low amount of air coming out of the vents could definitely be a compressor on it's last legs. ( it holds it's charge just fine. )
I've done a couple searches and I haven't seen anyone say slow blow from the vents could be traced to a bad compressor so I thought I'd ask you guys.
Thanks
Thanks
