So I've been scouring a lot (a LOT) of stuff on rockauto and others comparing dimensions, part numbers, etc. Here is what I come up with:
The late model 2003 to 2005 Jag S-Type "Sport" has a 320mm front rotor versus our 300mm. They used the same caliper part number and the rotors have the same depth/offset/etc. From what I can tell without holding an actual S-Type "Sport" knuckle to measure, they mount in similar places too.
It looks like all I need from an 03-05 S-Type "Sport" is:
Brake Caliper Bracket
New Rotors
New Pads
17" Rims (Already have! But listed for good measure)
Has anyone actually tried this yet? Cause if not, I'm going to see how it fits after I move into my new place with the garage. I tried searching this forum and all I could find were threads about the Jag S-Type "R" brakes. This is different from that.
So far my biggest problem is making sure the right parts are listed. If I do go forward and it works, I'll make sure I post all the part #'s I used and from where. Sadly my options for brake pads are limited. Would like to find a decent set of performance daily-driver ceramics of some sort.
New Rotors
New Pads
