diskfunktional
Okay thank you for the information Joe I appreciate it. I'll report back in 20 or so with the readings.
I wonder if a push over type tire pressure gauge wouldn't work well enough to check for pressure. It'd probably be worth a try.
The refrigerant fitting is larger than a typical schrader valve, so it will not work.
