Right on the Mark
Figured I would make these thought was they can't hurt right? I saw others make these 2 piece and I didn't like those 2 much movement.
Ok I'm going to have to make a disclaimer here because this is my car and I work on it how I please. This write up does not imply that this is the only way to do this or the best way.Just way I did it. That said,on we go.
To start I just welded a big 1/2-13 nut to frame sorry about primer pic its painted red now. LOL This is the bars rear mounting point.
Here is the bars middle mount point you can see that i machined thick 1/8 washer that fit tight into stock K-member hole and tight hole for the thru bolt.
Here are left and right bars welded up and painted.
Here is drivers side all bolted up to car.
The front mount hole in bar also has a tube welded into bar so the bar cannot crush.
