Adam Moore
Can't wait to see more on this in the next few months
As said quick LS was the test mule and has already proved how far the engine can be pushed.
What we dont know is how far the gen II engine can be pushed.
i dont have the funds to tear down my daily driver at the moment, and i really dont have the funds for a new engine so i can only dream for now.
I think these motors can handle 10psi just fine from the factory. that is not much boost if you see what other stock motors can handle.
This version of the AJ-V8 was never intended to be supercharged. The 4.0L and 4.2L are the ones that were.
The newest production AJ-V8 pushes 500hp from 5.0L...almost as much as the race version.
Hey Black---
From the emphasis in your comments, you seem to be fairly knowledgeable. I realize I'm thread-jacking to an extent here, but I'd like to hear about your background and experiences. Thanks!!
KS
You said heat exchanger and intercoolers in the original post, are you going water-to-air and using more than one intercooler?
If it is a supercharger, there is only one place I can think of to put the intercooler...between the blower and the intake manifold. Are there two heat exchangers you are putting on the nose of the car? Is that because of fitment issues that you cannot get one bigger exchanger up there?Water to air and two intercoolers is correct.. mimicing the Jaguar design..
Boost is boost. There are different ways of making it, from roots to centrifugal to lysholm to turbo, etc., but 5psi on one is identical to 5psi on the other. A larger blower will have more volume, and different methods "use" more horsepower to make the horsepower, which is where the differences come in.Whomever is concerned about what these engines can handle as far as "boost" I think you should research what boost actually is as its read from a guage. 5psi from an M90 and 5psi from a magnuson 2300 are on completely different terms. Quik had a 12psi pulley on his at one point IIRC so you guys saying 5 will blow the engine and are the max that fast should go are ridiculous.
I believe higher compression ratios N/A are also a consideration when boosting,
