American Air-1
I've heard several people complain about a leaking front end....even after replacing the struts with the Arnott aftermarket strut. After some testing on American Airs' own Mark VIII(Black Betty), I've come up with an easy and best of all.....cheap fix.
In my opinion, the problem lies in the solenoid housing itself, as I have found it to be "egg shaped" on certain units. The fix I've come up with is an special size o-rings that seals off any hint of air leakage.
Also, as I have preached for years that I recommend resealing the solenoids each time the solenoid is removed. With these Heavy Duty green epoxy o-rings, this is no longer necessary. The HD o-rings should endure countless install & removals without the need of replacement.
BTW, if ANY of my customers have purchased these struts from us in the last year and are experiencing this problem, I will gladly supply the needed seal kits to take care of your problem. All you need to do is pay the shipping.
