Installed new HID's today and I knew what happened was going to!
2002WRXSTi
Neshanic NJ
I got a set of the adaptors from DLF a while back and lost em in my room so I thought? Was figuring I should really get around to installing the bulbs before one of my stockers burns out.
BINGO driving back from Maryland the pass side burns out :mad:
So cleaning out my back seat I find that is where I stuck the adaptors. So I got to it today.
Pull out the stocker and do a comparison to the new bulb. Big difference huh :eek:
Then I see a typical Ford F up when I'm taking things apart :rolleyes:
And now to put the good bulb on EBAY and get a bit of money back maybe?
Well new bulbs seem to be nicer but just wondering how well they will work when the roads are wet? They are an Ice Blue output in my opinion and seem nice. I should taken a pick from inside my car last night to show it :rolleyes:
Now I have to adjust them tonight for aim since I no longer have the bubble levels :(
The bubble levels are useless imo. Just find a garage door and aim them on that. Thats what I do. Just keep them low and not too far left/right. You probably shouldn't have to aim them very much, they shouldn't have moved just from installing the new bulbs. I hate the gen2 headlight adjusters. Make sure the light bucket is actually moving when you turn the bolt. Fix that seatbelt yet?
Headlights where aimed at the ground before no matter how I adjusted them. now there aimed fairly far out but a bit to much to the left and down?
No belt is worse than ever now! You click it and it is nice and latched but then not even outta first gear and it lets loose :mad:
From about 10 feet away from the garage door I aim them almost perfectly straight out, it is usually nice and low and not too wide. Dude, replace the belt.
Hey what part of Maryland were you in. Im here in Maryland on the westside.
Elkton to go to the MVA
