xford
Green96 did a post that pointed out some LS Battery options from local BatteriesPlus locations. Since I was in need of a new one I went down to check them out. I wanted to stick with a vented OEM style replacement.
As Green pointed out they have a 650 CCA one for around $80 and a 750 CCA for $95 (both Rayovac). I confirmed both are vented in the OEM location and similar dimensions.
http://www.batteriesplus.com/produc...001-to-2005-V6-3-dot0L-750CCA-Optional/1.aspx
The sales guy then did a perfect up-sell and told me about their new AGM battery that is supposedly developed from the group that started Odyssey.
The battery is not even listed in the catalog yet (GRP 65 AGM Dual X2 Auto -Part #SLI65AGMDP) and is comparable in spec's to the Odyssey 65-PC1750T.
It's a sweet battery with 930CCA's, OEM type Venting, 5 yr warranty, and a perfect fit in my 2006 LS battery cradle. This thing has so much juice it feels like my starter is going to spin off it's mounts
It also has a Dual Zone setup so you can run your battery down using Accessory's and still have a fully charged zone to start your car.
The only down side is it's pricey at $239 installed but still less than the best price I could find on an Odyssey @ $286 which does not have OEM type vents. Crazy $$ but I figure it will be the last Battery the LS will get under my ownership...
