How do you know?
214rod
Dallas
If the swaybar end links need to be replaced? What are the symptoms? I'm about to have my shocks & bushings replaced so I'm just wondering if I should get anything else replaced while the suspension is getting worked on.
If they are worn you will get thumping,clanking noises(loose). If they are broken you will get body lean.
Visually inspect the rubber boots for damage and tears. Pry them with a screwdriver to check for excess play.
