If the swaybar end links need to be replaced? What are the symptoms? I'm about to have my shocks & bushings replaced so I'm just wondering if I should get anything else replaced while the suspension is getting worked on.
If they are worn you will get thumping,clanking noises(loose). If they are broken you will get body lean.
