pb blaster is better and its into the latch not the lock, but yeah and slam the hell out of it 20 times or till the light goes out
oh and :W to :V (everyones first post, your aloud one)
Surprises me that WD-40 is still so popular - it's useless at everything - never had a good experience with it. PB on the other hand... AWESOME.
http://www.snopes.com/inboxer/household/wd-40.asp
http://www.wd40.com/files/pdf/wd-40_2042538679.pdf
You sir are severly misinformed or your not using it for one of the 2046
things that it does.
• Use can to prop open windows
• Prevents the hydraulic unit on a BO105 helicopter from malfunctioning; Apply WD-40 every morning during daily inspection.***
i dont mind it but the wife hates it and bitches till the smell is goneGot to love the smell of PB ...
yup once you've used pb you wont even use wd to "prop open a window" lolSurprises me that WD-40 is still so popular - it's useless at everything - never had a good experience with it. PB on the other hand... AWESOME.
if it comes back on toss a switch in it. its cheapas far as i know the door ajar light on my ride has been on for 3 years..... previous owner spent over 3000 bucks chasing electrical demons and never figured it out. yall helped me fix it over night. no more door ajar warning. now i just need to fix the check air ride warning. My suspension conversion had instructions like cut the dark green wire on the grey plug in the 13 or 15 slot. i have no idea if thats right its from memory.
LOL this is exactly why I don't use PB on the latches.
Well is PB being used for cleaning or protecting here?
I would spray it down with CRC's P66 or something of the like, and then
coat it with corrosion X or Lear industries corrosion block (corrosion x is about half the price though) they both have a somewhat sweet smell that is unobtrusive, except when subjected to high heat.
Its just used to free up a sticky switch. No rust protection.
I would like to see some pics of your car. I had a willow green 95 and always wanted to see another one!
