KustomizinKid posted the guide below a while back, and I think I will follow it. However, are there any seals etc. that I should replace while in there? And, is the cobra housing the same so that I can re-use the stock one piece driveshaft? My car is a 1993.
Thanks.
You need a grinder what a cut off wheel.... here is how I did it on kirk's 97... took about 2 hours.
Drop exhaust.
Take off drivers side tire
Take off brake caliper and bracket as one part, slide off the rotor.
Undo the front knuckle spindle bolt, cut off half the head of the bolt
Undo all the knuckle bolt and slide the knuckle and cv out as one unit.
Pop the driver cv out of the diff, not all the way but just unclip
Take off the abs sensors
Undo the driveshaft
Undo the diff mounts and slide it out.
Reverse to reinstall.
