My engine coolant fill cap apparently has spider web cracks in it, very small. enough not to hold pressure though. My engine doesnt over heat, but i dont have any heat. Im thinking its created an airpocket that wont go away. It was low so it must leak coolant out to a certain point where it cant pressurize the system enough to cause more coolant to leak. also i dont think my hoses build pressure. Does this seem logical and everything related? Its very odd. but i think its whats causing the problem.
I filled it up with coolant and then it starts to pressurize and seep out through the cracks in the cap. This cap is supposed to be able to take pressure right? I dont think my t-stat is stuck as the engine operating tempurature is normal. When the engine is running is kind of freaky, sounds like its breathing, exhaling every so often :lol:
