FS: One-piece mark VIII aluminum driveshaft
PayUpSuka
Bear, DE
Actually came out of my '94 mark8. Has 143k on it, and in great condition. Looking for pickup due to size. Located in Bear, DE 19701.
Price: $125 OBO
-Mike
Do you have a pic of a 94 one piece DS or did you put it in yourself?
I pulled the car apart myself. I can get a picture when I get home from work. It's a very weird car for sure, cause when we pulled the motor the valve covers said 8/01/94. The door tag is something like 9 or 10 / 94. So I thought it was actually a 95.
Ok, just so you'll know. If you pull the shaft, it will come out in one piece but towards the back of it, if you see a gap in the shaft, it's a 2 piece. A one piece will be from a 93 only and will not have a gap in the aluminum at all. Maybe you have a 93 shaft that came in the car when you got it but if it has never been changed, it should be a 2 piece and again, it will hold in the hand like it is a one piece but with the gap, it's considered a 2 piece.
Ah crap, it's a 2 pieace then. I just thought that gap was part of the design. I had a 86 merkur xr4ti and it actually have a joint in the shaft and was flexing under suspension movement. That's what I thought I was looking for or something similar.
Ah crap, it's a 2 piece then. I just thought that gap was part of the design. I had a 86 merkur xr4ti and it actually have a joint in the shaft and was flexing under suspension movement. That's what I thought I was looking for or something similar.
I just didn't want you to send it off to someone and then they get it and well, you know the rest. When I pulled mine out of the 94 for the first time, I though to myself, it's in one piece lol. Turns out, with the gap being there next to the end, it is a 2 piece.
If someone wanted to, I don't see why they couldn't take the two piece and have that gap welded by someone that knows how to weld and fill the gap. It would then be a one piece shaft. I have a one piece in the garage and all I see where the gap is supposed to be or close to it is a nice welded bead. Balancing after the weld might be needed but still...
That joint you speak of, that's what I thought I was looking for too. Don't feel bad.
